No audio or Pan adapter
James Skala
James Skala Member
edited April 2020 in FLEX-6000 Signature Series
I have no audio or pan adapter,  smartsdr connects weird sounds coming form speakers.
Happened while monitoring.
After doing below trouble shooting getting 3 blinking red lights, do another hard reset back to original problem.
Voltage at Flex  13.87V
OS WIn 10
Running Intel I7 8700 12 Cores 16 gig of ram
Video card is a GTX 1060
Flex 6400 2.28 or 2.37
Done so far
Hard reset has been done
swapped Network cables
did Link Local direct connect to pc
tried a different pc same results
was at 2.37 when problem occurred.  went to 2.28 same issue.
HELP
KY4JLS
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    based on the three flashing reds...seems to be boot errorsee error codes below
    may need to reload radio s/w
    if that doesnt workthen most likely h/w issue and need to open help desk ticket
    error codes from manual6400/6600
    Power Button Color Codes
    The Power button is used to turn the radio on and off and is illuminated with a number of colors to indicate the radio’s operational state:
    * FLASHING GREEN: Radio is starting or shutting down
    * SOLID GREEN: Radio is in receive mode
    * FLASHING RED: See Error Conditions below
    * SOLID BRIGHT RED: Transmitting on PA
    * SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready. Refer to the SmartSDR documentation for description of the transmit interlocks.
    * SOLID ORANGE: Transmitting on XVTR port with low power
    * SOLID PURPLE: Radio is performing a software update
    * FLASHING WHITE: Radio is performing a reset to factory defaults
    * OFF: Radio is off
    * Error Conditions
Certain hardware and software error conditions cause the radio to stop operating and display an error code by flashing the Power button light as follows:
    * One red flash: Fan malfunction
    * Two red flashes: Software crash
    * Three red flashes: Boot failure
    * Four red flashes: Input power over voltage
    * Five red flashes: CPU overcurrent
    * Six red flashes: Input power under voltage
In the case of a software crash, the error code repeats for about 15 seconds, then the radio will reboot. In the other cases, the error code repeats until the Power button is pressed, then the radio shuts down. An additional press of the Power button is needed to restart the radio.
Avoid removing power from the radio when it is performing a software update (power button is solid purple). Doing so may result in the radio becoming unresponsive.
  • James Skala
    James Skala Member
    edited June 2018
    ***Update***
    I happen to hit my desk with my chair and the sound came back.  The I tapped the side of the Flex 6400 even more sound.  So I shut every thing down, and removed the top cover and inspected and pressed on all the cables and RF connectors.  Also found the metal heat sink Pre (PEN) was sitting on some round traces.  So  I removed the fallen heat sink and put cover back on and powered the radio up and behold "ITS ALIVE" and working.
  • [Deleted User]
    edited April 2020
    You should put it back in there on the chip and ty-wrap it in place
  • James Skala
    James Skala Member
    edited July 2018
    heat sink is back in place I used a tiny piece of Laird heat sink sticker and wire tie. Still waiting on a call or email when to send my radio in to get the official PEN for both procedures done.
