Spot display issue on Maestro with 2.3.7
Phil M0VSE
Phil M0VSE Member ✭✭
Hi.
I tried the new spot display feature with Maestro 2.3.7 during the UK CC 80m SSB contest and it worked brilliantly (with N1MM+ and Slice Master) and was a great way of quickly telling whether I had worked people (as it is only a short 90 minute contest, not many people get spotted).
I did notice one issue, if I zoomed-in (to see what the whole band looked like) the spots started to stack-up on top of each other and when zoomed back out, I was left with some remnants of spots still being displayed.
I have attached a couple of pictures that hopefully demonstrate the issue. Maestro needed a reboot to clear them (although I admit I didn't try removing/adding the slice).
Only a minor cosmetic issue on an otherwise GREAT new feature!
73 Phil M0VSE
    edited June 2018
    Phil, I have entered this problem report into our bug tracker (#6444) for additional investigation. Thank you for the defect report.
