USB debug Logging window with the Maestro... no scrolling possible
Jeff | VA2SS
Hi, I need to debug an issue here when using a FTDI C232HM USB adapter when used with the Ameritron RCS-12L. By I cannot watch much BCD values, because I cannot scroll down to watch the latest BCD information reported.. I do not want to reboot the TRX each time I need to watch more information than the initial window can display. I am using the Maestro with a Flex-6400. And no, I do not use a PC at all.... I don’t even have a PC, I’m using an iPad Pro 12,9 only. Any idea if I am missing something here ????
Thanks for your help. Best 73 de Jeff | VA2SS
Thanks for your help. Best 73 de Jeff | VA2SS 1
did the scroll bar work ?
Marc VE2PN
No, unfortunately...... Or I have to bigger fingers.... Hi Hiiiiiiiiii !!️0
I’m still need to scroll the logging window to debug an app using CAT control.... cannot scroll down.... Any clue to solve this issue without the needs to restart the Maestro ??? 73 de Jeff | VA2SS0
I woulD be useful to have a « CLEAR » logging button just besiDe the Enable button.... to reset the winDow logging information.0
I also noticed that not all USB cables in the Maestro are displaying the logging window correctly. Some of them, when the logging window is full, then the display scroll and you can see latest information at all time. But some of them, the scrolling do not work the same way.... when the display is full.... it keeps receiving, but does not scroll to let see the new values. It makes thing hard to use when logging window does not scroll properly. Will someone from Flex that will answer something on this issue? Best 73 de Jeff | VA2SS0
