Flex-5000, PowerSDR, and WSJT-X
K1SZO
Hello all,
I have a friend that has a Flex-5000, uses PowerSDR, and wants to setup WSJT-X with it. I've read the howto knowledge base article on setting these up, but the instructions seem quite dated and do not seem to jive anymore.
We were using com-0-com and VAC, but PowerSDR did not like it when I set the driver to Windows WDM-KS and the Virtual Cable 1 and 2.
Also, I can't for the life of me figure out how to get CAT control working either.
Does someone know of some updated instructions to get this configuration up and running?
73, David ~ K1SZO
73, David ~ K1SZO
RE setting up the CAT - you might make note of this one particular setting that drove me nuts till I finally figured it out. See this link to my previous post https://community.flexradio.com/flexradio/topics/wsjt-x-with-powersdr-and-dxlab
I have the same hardware setup, also using com-0-com and VAC. As driver for VAC I use MME. Though for CAT I use DXLab Commander.
No problems at all.
73, Peter - HB9BUN0 -
I use com0com, vac line 1 for in/out and omnirig Working fine for me
73 oz1hdf0
- 688 The Flea Market
- 105 Aurora
