Transverter Power
Steve
Steve Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
Power output changes with a 2 meter transverter when I change frequency??   I set the power slider to 100 and then on the transverter page I set power to equal 10 watts with the slider at 100.  When I change to another nearby frequency the power output changes?? I wonder if this is
a defect or am I missing something??
  • Marc Fröhlich
    edited June 2018
    I used a transverter via xvtr port at a 6300.
    The power-slider took no effect to the xvtr out pwr. Only the dbm value in the xvtr config-window at smartsdr. The power was stable for all frequencies in my case.
  • Rick - W5FCX
    Rick - W5FCX Member ✭✭
    edited June 2018
    Likewise for me.
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited July 2018
  • Doug Hall
    Doug Hall Member ✭✭
    edited June 2018
    Steve,
    Are you using any other software that communicates with the Flex, such as DDUtil? DDUtil's autodrive utility sets output power by band. If you change the slider and then change frequency the autodrive feature in DDUtil will do what you describe. But if you're not using DDUtil then I don't know what it could be. I don't see it here on my 6300.
    Doug K4DSP
  • Steve
    Steve Member ✭✭
    edited January 2019
    Larry, I am not sure if it is related.  I am hoping Tim reads this and lets me know.  Doug, I am not using DDutil.  Hopefully, like I said, Tim will contribute.  Thanks for the replies.
  • George KF2T
    George KF2T Member ✭✭✭
    The transverter port does not put out anything close to 10w.
  • Steve
    Steve Member ✭✭
    edited January 2019
    Sorry I was talking about the output of the transverter as it relates to the input supplied by the 6600.
