remote reset of radio ?
Marc Lalonde
Hi ok did have way to remotely reset 6600 radio to factory default ??
i got few sporadic crash since it start to be hotter temp now ,noting exaggerated PA of radio is no more of 35 deg
but now it just dead ,no bandscope or panadapter ,S-meter seem to indicated something even if almost no noise on audio , have try remote power cycle and also cycle the astron RS-35 power outlet but noting to do , it do same on local or remote PC and the Mastero
naturally the PEN is not yet do on that radio ,still wait the part , just hope heatshink not fall and shot on pcb ..
so i whit to be able to made factory reset for try to restart it
Marc, that is the symptom of needing the new heat sinks. You can tie wrap the old ones on until the new ones arrive if you need to. All heat sinks have shipped to those who requested them by mail.0
Hi Thank Gerald
that possible since just start to got first true summer day here 21deg ;-) but 35 on the "container"
i have here stock small heatshink similar to original one but whit time proven adesive to (294-1146-ND) ,so may try it when i return to the remote site ..
just curious/strange that got that symptom ,i assume it ADC and FPGA Clock go out of sync ??
but usually i use DCO signal for sync data bus capture ...
p.s. seem your right after all about my RX gain ,not yet do deep test but whit calibrated signal source but make many EME QSO during Dayton week-end radio pre-amp off ,still not got my echo but for now i look for other system component for find cause , so i probably own you a **** ;-)
Best regard
VE2PN
radio is back , have improvised a PEN whit heat sinks i have on hand , 1st have completely fall and second one hold by a corner ... , i also see a good reason for put it on backside , bad glue is hard to remove ,so better to put bit bigger one on the Back side
have brigs whit me the FLIR camera but 45deg temperature inside my remote station **** me
so i have keep work to stick bare minimum
- 407 Community Topics
- 704 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
