FRStack user manual for newbie?
Neal Pollack AB6G
Neal Pollack AB6G Member ✭✭
edited May 2019 in SmartSDR for Windows
I should be receiving my first Flex 6x00 radio this week, and have started reading to learn.
I came across the FRStack utility software, went to it's website, but find no docs.  There is
only a download EXE file for installing.   Does anyone know where the user manual lives so that I can find out what all it does, what controls/keys it uses, and perhaps see screen shots?
Thanks,
Neal   N6YFM
  • Jay Nation
    Jay Nation Member ✭✭
    edited May 2019
    Neal
    Most of the FRstacks documentation has been made available in posts here in the Community, there is also a rather lengthy help file built into the application itself.
    Once you download it and use it awhile, you will figure it all out. Mostly it's just switching features on an off, feature's explained in the in-app help file. There isn't much else. As each new feature was added it was announced and explained here.
    Try it out, you will likely never consider being without it.
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited May 2018
    There is a help document you can access from within FRStack. Run FRStack, click the Help Menu item on right side of menu, select View Help. If you still have questions that you can not find answered on the Community as Jay has suggested use the Contact Support menu item. Congratulations on your new Flex. 73
