Using ver 2.2.8.40 S meter works 6600M with white line at end of red but no S meter reading as on th
Dennis
Dennis Member
edited September 2018 in FLEX-6000 Signature Series
Why
  • Andy - KU7T
    Andy - KU7T Member ✭✭
    S Meter reading is only on the PC version, not on the radio. I like it too but there was likely not enough screen real estate on the radio.... just a guess. Andy KU7T
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    Confused my 6400M has the s meter numbers under the redline and the white peak line is there as well.
  • James Whiteway
    edited May 2018
    Wayne, I think you are looking at the SWR scale.
  • Wayne
    Wayne Member ✭✭
    edited May 2018
    On my 6400M the 2 default meters for slice a is pout for top and S meter for bottom. To get swr meter I have to touch the power meter and it toggles till I get to the swr meter which displays its own scale with the S meter still visible its always there I cannot change the S meter. This is stand alone on the touch screen but thats how the post indicated next time I have it on Ill post a picture.
  • Wayne
    Wayne Member ✭✭
    edited May 2018
    Now to change the s meter scale from s units to dbm that feature is only available if you are running ssdr for winfdows on a pc you cannot get dbm on the standalone radio s meter display if thats what he was referring to with v2.2.8
