IQ Stream Driver error
Bill English
Bill English Member
edited January 2020 in SmartSDR for Windows
I notice this has been an ongoing problem for many, I just noticed after the upgrade, that the active slice is red and says driver error on the IQ stream in DAX. I tried uninstalling and reinstalling, The odd part is after reinstalling it seems to work on RTTY and FT8 normally, but I still have the driver error showing.
Anyone else seeing anything like this?
Bill K4FX
    edited May 2018
    Did you just recently have your Windows 10 operating system upgraded to the 1803 Spring Update?  If so, then you are experiencing an issue many have experienced.  See this Community Message describing the issue and ways to resolve it: https://community.flexradio.com/flexradio/topics/important-notice-windows-10-update-1803-precautions
    If you are not running Windows 10 and are having the issue, please try the suggested steps to resolve in the Community Message I listed above.
  • kg5eiu
    kg5eiu Member ✭✭
    edited December 2018
    Hi Bill - I have the same experience.  FT8 seems to still be working okay.  I have to get a ticket going.
  • Bill English
    Bill English Member
    edited January 2020
    I got mine fixed. I had another issue with DDUtil and ended up uninstalling SmartSDR and reinstalling it and it fixed the driver issue too,
    Be sure and manually delete the user files under user/you/application data/roaming/flexradio sytems/*.* before you reinstall.
    That cured both problems for me,
