6600M audio coming from the unit while running Smart SDR on computer
Jeffrey Kerber, N3VE
Jeffrey Kerber, N3VE Member ✭✭
edited September 2018 in FLEX-6000 Signature Series
very faint audio coming from the radio while using Smart SDR, anyone else hear this with your external speakers off?
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    Did you turn off the front radio speaker in the ssdr for windows menu tab at the upper left under settings and radio tab?
    edited May 2018
    Jeffery,
    If you do not want to use the front panel speaker you have to disable it when using SmartSDR for Windows.  Go to Settings->Radio Setup-->RX and disable to option (at the bottom of the window)
  • Jeffrey Kerber, N3VE
    Tim, the front panel speaker is disabled.
    edited May 2018
    Could it possibly RF getting into the audio circuitry?  Try transmitting into a dummy load and see if you still hear it.
    edited May 2018
    Tim, it is receive audio. Just rebooted the radio and it is still there.  Should I try a factory reset?
    Jeff
     We can talk in Dayton.
    edited May 2018
    hard reset fixed the problem
    Jeff
    edited May 2018
    Thanks for the update.
    BTW, I'll not be attending Hamvention this year.  I'm not yet healed enough from my shoulder surgery in March to fly and do booth duties.  I do not want to risk the progress I have been making the last few weeks in PT.
