Slice Master 6000 fatal error
RV3FF
Hello!
Can't to run Slice Master cuz of fatal error: 'Failed to execute script slice_master'
Trying to run it on Windows 10
Got the programm here: https://github.com/K1DBO/slice-master-6000/releases
Hi,
When this happens it's usually a corrupt configuration file or a permissions issue. Can you tell me more about your installation? Has Slice Master worked for you in the past or is this a fresh install?
--Don
I just downloaded pack from the link above ( https://github.com/K1DBO/slice-master-6000/releases )
This pack includes 3 files (on the screenshot)
I don't have past versions of Slice Master
When I try to execute slice-master.exe I get the fatal error. (doesn't matter if I run it as administrator or user)
Thanks... please send me an email so we can work together to fix this.
--Don
Thanks for your help Andrey,
I've updated the release at github. v0.10.2a is now the latest.
--Don
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
