Low Bandwidth reset after local With Smart SDR
A.J. AJ2I
I noticed when I use the low bandwidth feature when using smartlink, when I come back into the shack and connect the the radio locally, the FPS and low bandwidth mode seems to be retained. Is there any way to have this reset back to normal operation after smartlink is disconnected? Obviously I know I can increase the FPS, just curious
This is working as designed. The low bandwidth feature configures your radio (not the client making the connection) to generate less network traffic by reducing frame rates, panadapter size, and limiting profile access among other things.
The radio really doesn't know if your client connection is via the LAN or a SmartLink connection, so the low bandwidth state is retained by the radio until you change it.1 -
Can there be a feature request for high bandwidth
Just load a global profile.0
- 694 The Flea Market
