How to get fldigi working with Flex 6300 on Windows or macOS
Scott
Greetings.
In 2015 I had the pleasure of meeting Matt and Gerald Youngblood and staff at the FlexRadio offices in Austin, and I ordered a 6300 on the spot. I've had fun working many states and countries with the JT65, JT9, and FT8 modes implemented in WSJT-X. Now I want to try other digital modes using fldigi. No matter what I try, I can't get fldigi to work with the 6300. I hope someone can help.
Context: My computer is a MacBook Pro running macOS 10.12 Sierra. Using VMware Fusion Pro 8.5.10, I run Windows 8.1 as a guest OS. I have SmartSDR 1.11.12, SmartCAT, SmartDAX, and WSJT-X 1.9.0-rc3 installed and working together in the Windows VM. I prefer macOS (and Linux) to Windows. A few days ago I bought dogparkSDR and Loopback and installed the xCAT and xDAX software kindly offered by Mario Illgen, DL3LSM. I was able to get WSJT-X 1.9.0-rc3 running on macOS and have made many contacts.
But I can't figure out how to make fldigi work with the 6300 either in Windows or in macOS. I'm baffled by the arcana of COM ports, multiple rig control mechanisms, and hundreds of configuration options. Is there a simple, straightforward, well-documented way to get fldigi working robustly with SmartSDR on Windows 8.1 or with dogparkSDR on macOS? I already spent a couple hundred bucks on dogparkSDR and Loopback and I hope I won't have to buy any more software just now.
Thank you.
Regards,
Scott
W6SDD
Thank you.
Regards,
Scott
W6SDD
I don't use FLdigi myself, but there is a lot of helpful stuff, including videos, out there.
https://www.google.com/search?q=using+FLdigi+with+SmartSDR&oq=using+FLdigi+with+SmartSDR&aqs=chrome..69i57.8719j0j7&sourceid=chrome&ie=UTF-8
Good choice of system for digital, Scott.
MacOS works very well with the software you have mentioned - of course it's a matter of configuration, and there are a few moving pieces. Having just completed this effort, I'll describe what I went through and provide the configuration screens.
First of all, you need to install Loopback, the licensed version (so there is no injected noise). Create two virtual audio devices in Loopback, as follows (choose names that make sense to you):
Each of the devices will be used for input and output routing, where xDax will be one side, and Fldigi will be the other. Tx in xDax takes the output of one device, and Rx in xDax takes the input of the other device.
Note that I found it important to REBOOT the Mac after setting up Loopback - I had some strange artefacts in the audio until I did that.
xDax is set up as follows:
Set up cat with COM port emulation or Ethernet connection. I chose to use the HamLib "rigctl", which talks to an Ethernet port provided by xCat. Set up xCat as follows (kinda the default, I think):
Use the RigCtl port number in Fldigi as follows:
And finally set up the Audio Devices in Fldigi as follows:
I don't usually even bother with dogparkSDR on the MacBook, because it is relatively under-powered, so I separately control the radio , in my case because I have a 6600M, from the front panel. I have used dpsdr at the same time, and it works fine to control the radio and set up the panadapters and slices (I used the 1.12 beta).
Here's the setup on my MacBook Air with xDax, xCat, and Fldigi doing FSQ:
That should be it - works FB for me, and is more sensitive that a corresponding analog setup with my K3 and SignaLink USB.
Ted VE3TRQ5 -
Ted,
You are amazing and wonderful! I followed your instructions carefully and got fldigi working with dpSDR and 6300 in just a few minutes.
Let me know if you're ever in Colorado. I'd like to buy you a **** or three. (And milk for the little one in your picture.)
Many thanks!
Scott
W6SDD
So happy you got it going, Scott. I think you'll find that wsjt-x will be a relatively simple job to set up, but again there is an extra moving piece, jt-bridge, if you want to log to MacLoggerDX. The xDax / xCat part should be pretty trivial once Loopback is set up for Fldigi. There are a number of guides to help with the job (I just have not yet done it - now that FT8 has taken over wsjt-x, I'm just not very interested - just not my thing to let the computer do all the work :-) By the way, if you are using a Mac, think about MacLoggerDX - integrates well with Fldigi using a simple AppleScript initiated by the logging macro in Fldigi, and the network abilities of both programs. Lots of information in the MacLoggerDX distribution. I have no skin in the dogpark game, just a happy user. Ted VE3TRQ1
JT-Bridge works great with MacLoggerDX, and you can use it with instances of WSJT-X running in a VM in W10 or if WSJT-X is running in MacOS. Simple and pretty easy to set up.... in fact it just logged a contact for me while I was typing this hi hi ;-)
Justin
KL2D1 -
Thank you all for responding to my plea with helpful information. I'm sure others will find these instructions helpful too.
See you on the waterfall.
Scott
W6SDD
- 696 The Flea Market
- 121 Aurora
- 983 Genius Products
