maclogger dx
Hope this helps.0 -
How did you get something to show in the port box.I cannot get anything there??
Once the radio connects with the app, the Port box should populate with the Rig ID (KF2T/3 in my case). Tickle the up/down arrows to see if it's hiding.0
oh ...by the way radio needs to be up and running either with dpsdr or ssdr or ssdrios before you will see the radio ID(name) appear in mldx0
I never see a radio name. Preferences shows it connected but in the upper left corner of MacLogger DX it shows opening. If you put your mouse over it shoes"the flex 6300 is not connected.
Hi Steve,
Are you sure the Mac running MacLoggerDX is on the same subnet as the radio ? Your screen shot is too small to read but if you have Port Type set to FlexRadio SmartSDR, the radio name will show up in the Port popup if they are both on the same LAN subnet.0 -
They are both connected to the router via ethernet cable so I assume they are on the same subnet.
Radio ip is 192.168.0.124
Mac is 192.168.0.115
mask 255.255.255.0
If you click on image it will get bigger
Firewall ? Please send the debug log - File menu Email Debug Log.0
Turned off firewall. Will send it when i get home. Do you want me to post it here or email it to you0
Email Debug Log will email it to me.0
Sent
Got it fixed . . . For some reason the Ethernet connection was set to a public network. Set it for "Private/Home and bingo it is working.
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
