compliments on transmit audio 6400M w/ Heil Proset and HC-6
Stephen Hawkins NG0G
I was surprised and pleased when I got 4 or 5 unsolicited compliments on my transmitted audio during CQ WW WPX Contest, SSB. I have made no adjustments from the way the radio came other then to tell the radio what mic I am using. The adapter cable to put the mic on tip and ring with the ground floating on the mic end is home made. This never happened using the same mic with my Yaesu FT-1000 MkV Field.
Same here Stephen many unsolicited compliments with my HC-4 cartridge. Great combo!0
You are right, the Flexes sound great with the default profiles for your mic.
Just think how great they will sound after you tweak them a bit for different purposes and fine tune them to your particular voices! WOW!0
- 688 The Flea Market
- 105 Aurora
