Received Maestro, SmartLink setup?
Hi all,
couple a month ago I ordered the Maestro and 6600. The Maestro arrived and I am really eager to test it.
I thought that I could setup SmartLink and probably get an account from someone to have the Flex experience as I have never owned one and really want to have hands on experience before I get my 6600.
I downloaded the v2.1.33 and ran it. Unfortunately I do not see a "SmartLink Setup" button. Is this behavior to be expected? If I cannot setup SmartLink w/o a radio in my network I guess I can not use it right now, given the case someone would have played me around a little with his Flex.
Any ideas?
Thanks and regards
Volker. DL4RCE.
Any ideas?
Thanks and regards
Volker. DL4RCE.
If you have a friend with a 6000 series FLEX take your Maestro over and connect it to his network and login into his flex radio and then you can setup SmartLink on the Maestro
then go back home and using HIS login and password you can connect and use his radio using SmartLink.
This is done as a security thing for the FLEX radio owners.
You must use the same version of firmware on both the radio and Maestro for them to talk so he will need to be on v2.1.33 like you have your Maestro on.
hope this answers your question.
73's
Bret
WX7Y
Hi Bret,
thanks for the answer, understood. Let´s see if someone does have a Flex in my area. Unfortunately it is not as popular as in US (do not know why...). So chances are not that good
Volker, DL4RCE.
- 694 The Flea Market
