My 6400M is alive and I believe well.
Very nice, keep us in the loop how things are going there.0
Going to be a learning experience for me. Soon as I get a pic from my phone to this pc, i will post a pic.
first order of the day...
turn every knob and see what it does,
then
push every button and see what it does
and
now you can push every knob and see what it does
then
walk thru all the menus...
now you will know what things lurk inside the radio ;-)
OH Yea...always good to have the manual by your side to help explain what you are seeing
seeing the real thing vs seeing what the manual says
and
OH by the way some popup menus are mode sensitive, will see different display if in ssb vs cw fro example
i spent first two days with my 6600M just doing the above. this way i knew it existed in the radio..i just had to find it again ;-)
then operated for a few days and then played again with knobs and buttons
and started to setup the rig the right way for my style..
and
that also improved my "muscle memory" so i would reach for the right knob
all i can say , Model M's are one really nice radio.
enjoy
picture . not in it's right palace yet but it's working. will spend the next week or so getting use to it.
Spoke too soon. Flex screen is sideways. monitor screen is the right way but it is very small.
Unplug the HDMI Monitor cable from the back of the 6400M. Now quickly press the power button to shutdown the radio wait 10 seconds. Press the power button let the radio load. when its ready for operation turn your HDMI monitor on and then plug the HDMI cable into the HDMI jack on the flex. Now all should be correct.
This has previously been reported as an issue to flex as bug tracker #5989.
Am I going to have to do that every time I turn the radio on and off. Not good.
This is a known issue as you know, I think to fix it what they are doing is, to make sure the radio is booted up then plug the monitor in.
I was hopping they addressed that in this last release.
other wise, very impressive0 -
Until they get it fixed. I don't know if the fix was included in version 2.1.33 or not I have asked here.
I have waited to connect my HDMI monitor waiting on a fix. Trying to change the resolution in the display utility on the 6400M intel screen has only resulted in a very small 6400M screen and did nothing that would be acceptable for normal use.
I even have my HDMI connected to a switch and the switch had the monitor connected to another computer HDMI and selected not the flex but as long as the HDMI cord was plugged into the flex it would boot the flex screen sideways but the HDMI monitor screen was in the correct orientation.
No fix yet. Hang in there.0
- 688 The Flea Market
- 105 Aurora
