Error new version 2.1.33 Flex 6500
Javi LU5FF
I'm having problems installing the new version,
these are the warning signs that appear to me,
I had never happened
any ideas?
error 1
error 2
any ideas?
error 1
error 2
Hi Javi, It’s probably your antivirus. Pause it while installing and updating the radio.1
Hola Ria, Thanks for the help tomorrow I will try to have what happens
You may have to rerun the installer after you turn it off if virus protection removed the firmware files.2
I had similar problems installing a previous version. Even though I AM the
Administrator - some programs will not install unless you right click (the .exe file) and "Run as Administrator"
Windows 10 Pro 64bit, Avast Anti Virus still on, software upgrade ran without a hitch for my 6500!2
SmartSDR doesn’t require admin privileges. I would strongly recommend against that.0
Usually we on the alpha team “seed” the file to our antivirus software vendors so when it is generally available they have a signature for it. So in that case it will work. Ria0
Tks Tim0
It went smoothly as usual with my Flex6500. I had expected some new functionality with it, but ....
I hope FRS updates SmartSDR more frequently with new functionalities.
By the way, recent Windows Insider Preview, 17115.1 rs4_release, killed my DAX and forced me to go back to the previous version. JFYI.
73 de JI1BNU
Ken Yamad
This was simply a maintenance release.1
Anti-virus could the be cause of your problem, but it is also quite possible that you simply have a corrupted copy of the installer. We had a similar problem reported in this forum a week or so ago that turned out to have been caused by a shaky Wi-Fi system that corrupted the file. You might try simply downloading it again and trying again.
No problem installing with BitDefender on.
Bob0 -
This is not an installer issue. The installer elevates it's rights to Admin for the install. If you have a 3rd party security app that circumvents the rights elevation, then this issue will occur.1
I have to disagree with Ria. The CD I got with my 6400 would give similar errors as above and would not install SmartSDR (Windows 10 and I am the administrator). When I right clicked on the .exe. and used "Run as Administrator" it installed just fine.
All of my installs didn't require "Run As" I am local admin on my machine Windows 10 Pro 1703. I think it's an issue tied to each users computer.
hi all OM´s
Thanks for all the comments!!
everything remains the same
disable the antivirus - same warning windows
disable the malware - everything is the same
uninstall antiviruis and malware and everything remains the same
uninstall the smartsdr version, I cleaned the registry and the same problem
download 3 times the software see. 2.1.33 for doubts and the same problem
reinstall version 2.1.32 and install without any problem -- %-)
Windows 10 Ver 1709.
If we take the error message "source file corrupted" at face value, time for some checksums:
unix:~/Downloads$ md5sum SmartSDR_v2.1.33_Installer.exe
01fb54245d192feb885add1e6c413380 SmartSDR_v2.1.33_Installer.exe
and
unix:~$ md5sum FLEX-6x00_v2.1.33.106.ssdr
a8fec6f6c09909cb3628de56909981c9 FLEX-6x00_v2.1.33.106.ssdr
the file FLEX-6x00_v2.1.33.187.ssdr in C: ProgramData FlexRadio Systems SmartSDR Updates - it is not generated
I still have the FLEX-6x00_v2.1.32.104.ssdr
If I ignore the error, it installs,
but I do not want to update the equipment just in case
the problem was not yet resolved.
I will wait for a future update
how rare that version 2.1.32 installs without any problem like all previous
and this last one gives me error.
thank you all for your messages
73s
Javi LU5FF0 -
I recently had to disable Avast due to stability issues. SmartSDR now running stable. I plane to introduce Avast again soon. Major issue was that it was interacting in some way with the com ports. Both the computer ones and VSP also. I think it is a localized issue at this point. I will update when I reintroduce Avast.0
HI OMs
I have disabled the Antivirus as requested
But the error remains
I see there is no certificate added to the installer file
ver. 2.1.32
Ver. 2.1.33
