Rf attenuator / SCU Gain
Is there anymore info than that as far as the value of db that is inserted as attenuation or gain that the slider matches up with?
If you look at the screen on the top right as you move the slider, you will see a value which changes from -8db, 0 (nothing on screen), 8db, 16db, 24db, 32db0
Got it thanks revisited the manual and there it was in black and white.0
What page Wayne. I have a neighbor that is about 200 feet from me that is on the same band as I am.
OK. i have a neighbor who's antenna is about 150 feet from mine. I have not been able to find any type of attenuator to attenuate his signal. at times we are on the same band. I am on 7.222 and he is on 7.251. I read the info on page 162. Can someone point in the right direction.
Maybe make sure you receive filters are set to steep.0
What page in the manual that discusses this. i.e. receive filters Is it in equalization in the audio tab??
I don't have one of the new radios, I have a 6500 SSDR for windows. Under radio setup/filters0
The 6400M manual states it can be adjusted from -8db thru +32db in 8 db steps. Therefore the bar from left to right per position or click is: -8 / 0 / +8 / +16 / + 32 / Any position choosen which is NOT Off (0db) results in the setting such as -8db to be shown in the upper right corner of the Panadapter.
However since there is only 1 SCU on the 6400M you cannot have a different setting of the Preamp per Panadapter the preamp function applies to the SCU however is displayed on the Panadapter'
Reference Page 84 of the 6400M/6600M User Guide Version 2.1.30 published 1/29/18.
The problem is that your neighbor is physically too close and depending on the frequency, your antennas may be in the near field of each other. The attenuator in the radio is not designed to address this type of issue. External filters with much greater attenuation will be necessary. And if you are on the same band, any attenuation will inhibit your ability to receive weaker signals. Your only choice, if he is on the air, is that you are on a different band. And possibly one that is not harmonically related to the one he is operating on.0
Thanks Tim. that's what I thought. He is net controller on one and I am a net controller on another one. His is in the AM and mine is PM. I normally just check out when i see his signal up the band. I have no problems with that.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
