SO2R behavior of the ~ button (muting and unmuting the unfocused RX) no green light
Matt NQ6N
Matt NQ6N Member ✭✭
edited April 2019 in Third-Party Software
It seems that when doing SO2R, all of the normal OTRSP operations work as expected with N1MM+ Logger, except for the ~ key. Pressing the key correctly toggles the audio of the unfocused RX, but it is not toggling the green light in the unfocused entry window of N1MM+ Logger as it is supposed to.
I'm curious if others have seen this behavior.  I am comparing the behavior of the 6600 + SmartSDR to the behavior I had experienced previously with the YCCC SO2R box.
Since it seemingly works correctly using the YCCC Box, I'm inclined to think this may be a bug in the Flex software.  Any tips or insights would be much appreciated.
Matt NQ6N
  • Kari Gustafsson SM0HRP
    Kari Gustafsson SM0HRP Member ✭✭
    edited April 2019
    I think you are right. I use now and then N1MM IN SO2R with a remote 6700. But should it not be this way as tilde key only toggles stereo mode and not receiving/entry focus?
  • Matt NQ6N
    Matt NQ6N Member ✭✭
    edited April 2018
    I posted the issue on the N1MM reflector and indeed you are correct. The intended meaning of the green dot is simply to indicate which entry window is active.
