6400M doesn't connect to DAX/CAT upon startup
Never had any problems connecting 6500,6700,6300 to DAX/CAT in the past....I am fustrated at this point. About ready to return 6400M to Flex and order just the basic 6400.
Am I the only one with this type problems?
The multi screen boot up process on the M series should be corrected for users who have only 1 radio online and use the current, latest version of the software, but I can live with this process if the 6400M would boot up to DAX/CAT without multiple attempts. I know I can leave all powered up but here in FL, thunderstorms daily are the norm requiring disconnecting AC and antennas.
Hi Jim, Just tried to reproduce your problem here with the radio off initially: I started my PC and DAX & CAT utilities started automatically. I then started SmartSDR on the PC which launched and as expected did not see my 6400M.
I then started the 6400M and after the FlexRadio splash screen the radio appeared in the SmartSDR list on the PC. I was able to connect just fine. I also noted that the DAX and CAT utilities had actiove connections to the radio.
I re-tried the scebario 3 times but cannot reproduce the problem you are having. Hopefully it will turn out to be some configuration issue.73, Mike KE4U
Did you connect to the 6400M via the computer or let the 6400M connect on its own. I have no trouble using smartsdr on the computer connecting to the 6400M, just as you would connect SmartSDR to a 6300, 6500 or a plain 6400.0
OK Jim - I understand I think.
I powered up the PC (DAX and CAT utilities both start automatically). Then I powered up and connected the 6400M front panel several times.
Each time, the PC-resident DAX and CAT utilities reported a connection and I was able to run my logging program (uses the CAT interface) and FLDigi (uses the DAX interface) with no problems.
Note on my network topology here: Network connections between the PC and 6400M are via an ethernet switch.0 -
Yes, your example here is what I am trying to do. The DAX and CAT both start automatically at computer boot up just fine.. When I start the front panel as you indicated, the 6400M doesnt connect to the DAX and Cat about 50 percent of the time.. Once it has connected you can restart the 6400M and it will connect again all the time.. Almost appears a timing problem but I am not sure. Thanks for the info.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
