DEXP not working
Dan KG0AQ
Dan KG0AQ Member ✭✭
edited December 2019 in SmartSDR for iOS
Great program! I just got back from Oregon and used this program several times and it worked great. Outstanding TX audio reports too! During that trip I could not get the DEXP to work at all. I tried different headsets and the built in mic for the IPhone and IPad. Is there a trick for getting this function to work? TIA!
  • DV
    DV Member ✭✭
    edited March 2018
    Sounds like you were working remote, if so, DEXP does not work when remoting, only for direct microphone into the Flex unit.
  • Dan KG0AQ
    Dan KG0AQ Member ✭✭
    Bummer.  Thanks for the info.
