Praise
Tom Stahl
My 6400 came in yesterday, and is up and running today. I had absolutely no problems in getting to load. So far very happy. Currently 8 hours in on 72 hour burn in. Patience is a virtue. Wait until the green light stops blinking, select update and wait a few minutes and then connect after the update. I have some special apps that worked with the 6300 and they still work!! FLDigi was still on the machine although I had taken every thing off that dealt with the Flex from the 6300 days. FLDigi fired right up on both slices. Will advise if there are issues during the burn-in.
Using Windows 10 Home 64 bit; AMDFX-8370 and 16 Gigs of RAM ---73 tom WB8LDW
Brilliant, mine is on back order (UK based), can’t wait 73’s paul, GW4AMZ0
- 685 The Flea Market
