Noisy 6400M VFO Knob
KS4JU
My 6400M main VFO knob makes a slight scraping sound when turned. It sounds like a piece of paper or plastic is touching the face of the rig as the knob spins. Anybody know how this knob comes off so that it can be checked? It's not obvious to me whether it just pulls off or the rubber outer grip has to be removed to get to a set ****.
If its like the other knobs the rubber cover comes off to get to the set ****.0
Hi Mike. I have the same problem. Have you fixed it?0
Just pull the rubber grip off and losen the set **** on the wheel, pull the knob out slightly.0
Different subject but good pics on knob
https://helpdesk.flexradio.com/attachments/token/vos2HKdDGSVYkA82lWoQJMoOS/?name=Maestro+VFO-A+Balan...
Thanks Bernie. Appreciate that!1
