Flex 1500 CWX issue
Tim VE6SH
Tim VE6SH Member ✭✭
I am a new Flex 1500 user and have an issue with CWX and PowerSDR 2.8. I believe I have set the correct parameters for the keyer and PTT, but I cannot get CWX to properly key the radio. Using CWX I can hear the 1500 relay click to TX and hear the sent characters through the speaker but no power out or indication on the panadapter. Any ideas? Works fine on all other modes. Tim VE6SH
    edited February 2018
    Have you verified the power output by using an external power meter?
  • Tim VE6SH
    Tim VE6SH Member ✭✭
    edited March 2019
    Tim
    Yes, on DIGU and SSB I have confirmed power out. On CW there is no power showing on an external meter.
    Tim VE6SH
  • Charlie_KB8CR
    Charlie_KB8CR Member ✭✭
    edited February 2019
    Tim (VE6SH) :
    Did you ever find out a solution? My 1500 does the same thing.
    Charlie KB8CR
  • Tim VE6SH
    Tim VE6SH Member ✭✭
    edited March 2019
    Charlie
    Shortly after I posted this it started to work. Not really a solution I know as I did not do anything! I have since sold the 1500 and I understand the new owner has no issues.
    Tim
  • Charlie_KB8CR
    Thanks for the reply, Tim. Oh well.....problem here is that my Watt/SWR meter is internal to my tuner (AT100Proii), and that is mounted in the rack in the basement below my shack. I've just been sending everything with my paddles instead.
    Charlie KB8CR
