SmartSDR v2.1.32 Now Available
Tim - W4TME
Tim - W4TME admin
edited March 2018 in SmartSDR for Windows
FlexRadio Systems announces the immediate availability of SmartSDR v2.1.32 for the FLEX-6000 Signature Series SDRs.  SmartSDR v2.1.32 is a General Availability (GA) maintenance release containing fixes for SmartSDR for Windows, SmartSDR for Maestro, SmartSDR CAT and DAX.
SmartSDR 2.1.32  can be downloaded from the FlexRadio Systems web site. Please download and review the SmartSDR v2.1.32 Release Notes prior to installing SmartSDR v2.1.32 to ensure an optimal software installation experience.
A software license for the FLEX-6000 is required to run SmartSDR v2.1.32.  If your FLEX-6000 has been authorized to run a previous version of SmartSDRv2, re-authorization is not required.
All owners of the Limited Edition (LE) FLEX-6700 and FLEX-6500 SDRs or radios sold after May 19, 2017, have been pre-authorized for SmartSDR v2 and do not require the purchase of a SmartSDR v2 license.  To run SmartSDR v2 on all other radios requires the purchase of a software license for the radio.
Obtaining and validating a license for your FLEX-6000 software defined radio is a simple process.  Once the radio and client have network access to the Internet, just load any version of the SmartSDR v2 software on your PC or Maestro.  In the radio chooser, if a radio requires a license, a status message will indicate a license is required before connecting to the radio and updating the firmware.  A “Buy” button is also presented so that you can conveniently purchase a SmartSDRv2 license using our Online Store.  Please see details below regarding purchasing a SmartSDR software license for your radio.
The following highlights are SmartSDR specific items:
FIX: A defect in Band persistence prevented power levels by band to be set and recalled properly.
FIX: The KY CAT command failed to ignore trailing characters in a text string resulting in long delays when multiple KY commands were issued.
FIX: Right-Click on Panadapter context menu now closes properly when enabling or disabling Tune Guides
FIX: Resolved a problem with low power output between 1.884170 MHz and 1.892350 MHz on a FLEX-6400(M) and FLEX-6600(M)
FIX: Resolved a signal level issue after direct frequency tuning a slice receiver on a FLEX-6400(M) and FLEX-6600(M)
The following highlights are Maestro specific items:
FIX: Corrected a display issue with the Maestro Startup logo when connecting to a FLEX-6400M and FLEX-6600M
The cumulative SmartSDR v2.1.32 Change Log detail is listed below.
v2.1.32 (2018-02-06)
#5934 Maestro: Fixed an issue with the startup logo when connected to an M model radio
v2.1.31 Alpha (2018-02-02)
#5921 Fixed relay click and level change after direct frequency tune (WIDE status recalculation)
#5906 6400/6600: Fixed low power between 1.884170 MHz and 1.892350 MHz
#5894 Fixed power per band retrieval
#5919 SSDR: Single click tune now works inside of the Slice filter
#5920 SSDR: Right-click context menu no longer stays open after enabling/disabling Tune Guides
#5960 CAT: KY command no longer sends trailing white spaces per Kenwood spec
#5916 API: SmartLink TcpClient object is now cleaned up properly when closing the connection
#5528 API: A more readable exception is thrown when API.ProgramName is not set before KeepAlive is started
#5326 SSDR installer Release Notes and ChangeLog now open web links in browser
