FT8 monitor gain
AH0U
Using a 6700 and the 1.8.0 ver. of WSJT.....Wide Graph shows a screen full of very strong signals and the Band Activity decodes them all BUT the monitor graph is always in the red....about 9-10 db... no matter where I slide the RX Gain on the DAX panel it does not change the monitor which sys it should be 30db and mine never gets out of the red
Hello,
The "Intensity" of the waterfall is set by clicking on the "Display" in the upper left (Not DAX).
By sliding the "gain" you will change the waterfall "color"
"Rate" is how fast the waterfall moves
"AVE" is how sensitive ("bouncy") the signal trace is
Another one that is helpful is under "ANT" - You can change the RF Gain
enjoy!
Charley1 -
... or you try the Windows internal MIC slider ( Win lower right corner, right click on speaker symbol and then click recording device ...
Charley is spot on. Set your level first so its running he correct level. I run my about 70 to 80% if possible.
Then the waterfall "look" is controlled as Charley said. Its a little twitchy but once you get it set to your liking you are pretty much done.
- 408 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
