Does the 6600M have relay or pin diode filter switches?
David Salomon
David Salomon Member ✭✭
I may be using my new 6600M for MIL-ALE-141 via PC-ALE or MARS-ALE (or both).  When scanning, the software can do up to 10 frequency switches per second (multiple bands).  A radio with relay switching for the filters will die quickly under those conditions (at least the relays are likely to die an untimely death).  A radio that uses pin diode switching should fare much better.
So, which is it for the 6600M?
73 - David, AG4F
    edited April 2020
    This is a fallacy that the radio will die quicker with relay switching.  The relays are rated for a very high number of actuations.  I did the math a while back and if the radio ran 7x24x365 with a band change every 10 seconds, you will not hit the rated spec for something like 10 years.
    BTW, it is a reed relay, not a pin diode.
  • David Salomon
    edited April 2020
    Tim -
    Thanks for the elmering!
    So the 6600M is using reed relays vs mechanical relays, correct?
    73 - David, AG4F
  • KC2QMA_John
    KC2QMA_John Member ✭✭
    edited February 2018
    WOW I’m glad to hear that they are reed relays they are super reliable and fast.
  • David Salomon
    That makes two of us.
  • Joe  N9VX
    Joe N9VX Member ✭✭
    Is the same relay used in the 6400?
    Yes
    In QSK mode, it uses a reed relay.
