SSDR 2.1.3 Problems...
Lasse Moell
Lasse Moell Member ✭✭
edited February 2018 in SmartSDR for Windows
Since upgrading to SSDR 2.1 I have had my radio (6500) twice hang hard in the middle of a transmission. Only a long push on the power button brings it back.  This never happened  to me using 2.0 nor one of the latest 1.x s/w. Anyone else seeing this?
/Lasse SM5GLC
  • Chris
    Chris Member ✭
    Yesterday one time and today until now one time my 6k5 stopped receiving and shutted down.
    I only had to restart SmartSDR.
    73 Chris DK1QG
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    If  you have not yet. Perform a factory reset on your radio. Make sure you Export your profiles before performing reset. Factory reset info can be found using the link below.
    https://community.flexradio.com/flexradio/topics/factory-reset-6500
    Once reset, Import your saved Profile settings.
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    If we are talking in a transmission I would also suspect some RFI.  Until I changed antenna setup I could **** my computer with enough transmissions.   Now the problem is gone with some better RFI isolation.
    Also, as per the release notes, a cold boot of the radio is recommended (power down the radio, remove power for 10-15 seconds, restore power, reboot the radio).
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    A cold reboot in life can really fix most things. My favorite saying while in IT was turn it off, turn it on ( I mean really turn it off). Next is return to factory settings. Last was look in the mirror.
