SmartSDR v2.1.30 Now Available
Tim - W4TME
Administrator, FlexRadio Employee admin
FlexRadio Systems announces the immediate availability of SmartSDR v2.1.30 for the FLEX-6000 Signature Series SDRs. SmartSDR v2.1.30 is a General Availability (GA) release containing the initial support for the FLEX-6400, FLEX-6400M, FLEX-6600 and FLEX-6600M, new features and fixes for SmartSDR for Windows, SmartSDR for Maestro, SmartSDR CAT and DAX.
SmartSDR 2.1.30 can be downloaded from the FlexRadio Systems web site. Please download and review the SmartSDR v2.1.30 Release Notes prior to installing SmartSDR v2.1.30 to ensure an optimal software installation experience.
A software license for the FLEX-6000 is required to run SmartSDR v2.1.30. If your FLEX-6000 has been authorized to run a previous version of SmartSDRv2, re-authorization is not required.
All owners of the Limited Edition (LE) FLEX-6700 and FLEX-6500 SDRs or radios sold after May 19, 2017, have been pre-authorized for SmartSDR v2 and do not require the purchase of a SmartSDR v2 license. To run SmartSDR v2 on all other radios requires the purchase of a software license for the radio.
Obtaining and validating a license for your FLEX-6000 software defined radio is a simple process. Once the radio and client have network access to the Internet, just load any version of the SmartSDR v2 software on your PC or Maestro. In the radio chooser, if a radio requires a license, a status message will indicate a license is required before connecting to the radio and updating the firmware. A “Buy” button is also presented so that you can conveniently purchase a SmartSDRv2 license using our Online Store. Please see details below regarding purchasing a SmartSDR software license for your radio.
The following highlights are SmartSDR specific features:
The cumulative SmartSDR v2.1.30 Change Log detail is listed below.
v2.1.30 GA Release (2018-01-26)
#5869 Fixed hang when disconnecting SmartSDR for Windows after update
v2.1.29 Alpha (2018-01-25)
Miscellaneous fixes
v2.1.28 Alpha (2018-01-24)
#5862 API: Radio nickname is no longer cleared out when the radio disconnects
#5854 Maestro: Fixed a crash when changing bands with a diversity slice
v2.1.27 Alpha (2018-01-23)
v2.1.26 Alpha (2018-01-19)
#5731 SSDR-Win: DIV button on Slice Flag can no longer be pressed if there are no more Slices available
#5782 13.8V Meter fixed
#5575 High power into receiver protection messaging improved
#5709 Unplugged USB Cables now have a different appearance and are properly disabled in the GUI
v2.1.25 Alpha (2018-01-12)
#5539 TX1/TX2/TX3 radio outputs no longer momentarily activate during radio bootup
#5507 GPS LED is now turned off when the GPS is uninstalled
#5638 Diversity slices that are created now have the correct NR value
#5505 Default FHM-2 microphone profiles now have bias turned on
#5603 CAT: Fixed crash when shutting down the radio
v2.1.24 Alpha (2018-01-09)
#5640 Maestro: Fixed rapid updating of available wifi networks on v2 model
v2.1.23 Alpha (2017-12-29)
#5562 SSDR: RF Gain slider ball is now aligned properly with markers
#5495 CAT: Fixed an issue that could cause CAT to crash
v2.1.22 Alpha (2017-12-22)
Miscellaneous fixes
v2.1.21 Alpha (2017-12-19)
Changes for initial Alpha release of FLEX-6600
v2.1.9 Alpha (2017-12-07)
Miscellaneous fixes
v2.1.8 Alpha (2017-12-01)
Miscellaneous fixes
v2.1.7 Alpha (2017-11-21)
Miscellaneous fixes
v2.1.6 Alpha (2017-11-21)
Miscellaneous fixes
v2.1.5 Alpha (2017-11-17)
Miscellaneous fixes
v2.1.4 Alpha (2017-11-14)
#2021 SSDR: Made changes to meters and slight changes to color scheme for improved readability
#2248 SSDR: Mouse cursor frequency guides option now added (Right-click on Panadapter or waterfall)
#2248 SSDR: Single click to tune option added (Settings -> Radio Setup -> RX tab -> Single click to tune)
#5322 SSDR: "REMOTE" button on upper right now renamed to "PC Audio". Also fixed an issue with PC default sound device detection.
#5289 SSDR: Fixed tooltip positioning for pages: Profile Manager, Memory, Waveform, USB Cables.
#5302 SSDR: The current slice preset filter button is now highlighted on startup when it is the selected filter
#5048 SSDR: Fix popout windows not closing on disconnect
#5329 Maestro: Fixed issue of Wifi MAC address not appearing on new Maestro units
#5295 Maestro: Fixed problem going from diversity profile to non-diversity profile causing UHEs
#5179 Maestro: Updated Ethernet driver
#1309 Nickname, Callsign, Model buttons now removed for Flex-6300 since it does not have a front display
#4354 TX high/low cut controls now have "TX Filter" label for better clarity
v2.1.3 Alpha (2017-10-05)
#5273 SSDR: Slice Flag DIGx Offset, RTTY Mark, and RTTY Shift controls can now be changed with the mouse wheel
#5204 SSDR: Import/Export Window button placement is now correct for different Windows screen scaling levels
#5235 Maestro: Audio menu Headphone and Master Volume control positions are now swapped to be more consistent with SmartSDR
#5275 DAX: Sliders can now be controlled with the mouse wheel
v2.1.2 Alpha (2017-09-29)
#5256 Maestro: Right BW Select knob now changes TNF frequency/bandwidth in steps of 10 Hz, compared to the left BW Select knob (1 Hz)
#5254 SSDR: All left/right button fields (RIT, XIT, High/Low Cut etc.) can now be changed with the mouse wheel
#5251 SSDR: Slice flag sliders now show numeric readout while dragging
#5250 SSDR: Sliders on CW panel can now be scrolled with mouse wheel
#5252 SSDR: Sliders in Pan Menu -> ANT controls now behave like others
#5260 SSDR: Active Slice panel L/R Pan buttons now snap to left, center and right (center was missing before)
v2.1.1 Alpha (2017-09-27)
#820 Added Panadapter Fill to both SmartSDR and Maestro
#1891 Maestro: Added TNF capabilities
#1867 SSDR: Mouse scroll wheel now adjusts sliders
#466 SSDR: Slider values are now shown when adjusting
#4786 Maestro: Popup info that displays when a knob is turned no longer prevents user from touching the Menu button
#5205 Maestro: Cleaned GUI overlapping with the SmartLink Log In button
#5077 SmartSDR: Hovering mouse over network bars at the bottom now results in a properly aligned popup
#5192 Pop-out Panadapters now have a minimum size
#5181 Maestro: fixed a UHE on startup
#4508 SmartSDR Radio Settings menu now has more room for longer IP addresses
#5049 SSDR Network Diagnostics window text is now aligned properly and no longer truncated at the bottom
- Panadapter Fill: Panadapters can now optionally be shaded in. This feature can be enabled in the Display menu, where the intensity of the fill can also be adjusted.
- Tune Guides: Allows you to conveniently view the frequency at the location of the mouse as it moves over the Panadapter or Waterfall. This feature can be enabled or disabled by right-clicking on the Panadapter or Waterfall and clicking “Tune Guides”.
- Single Click to Tune: Allows you to tune the Active Slice to current mouse cursor location with a single click instead of a double-click. This feature can be enabled or disabled in the RX tab of the Radio Setup menu.
- Meter redesign: Meters in SmartSDR for Windows have been redesigned so that they are easier to read.
- TNF on Maestro: Controls to create, modify, and delete TNFs are now available on Maestro by touching and holding down on either the Panadapter or Waterfall
- Mouse Wheel Control: Most numeric controls in SmartSDR for Windows can now be adjusted with the mouse scroll wheel for ease of use.
Miscellaneous fixes
Miscellaneous fixes
Miscellaneous fixes
Miscellaneous fixes
Miscellaneous fixes
Miscellaneous fixes
Miscellaneous fixes
7
- 685 The Flea Market
