SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Looking for power supply recommendations
George;
There are a lot of options. I have been very satisfied with the three MFJ 4230 power supplies I have, one for each rig. There is no discernible rf noise. I have run the Flex on battery while using the MFJ, and any noise is below the internal noise of the Flex. Mine is mounted beside the 6400 to keep the connections short. The connections are on the rear rather than the front for a clean looking installation. The front panel voltage adjustment allows the output to be adjusted to compensate for wiring losses,so that the the Flex sees the desired voltage during transmit.
Hi, i try to service my GSV-3000 a copy of FP-1030A power source.
Please can you tell me the transformer secondary AC voltage for both coils? I am measure 17Volts on main coil and 0,5V on secondary coil. Thank you in advance.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
