IQ Streams shows No Panadapter on 6500
Paul
I've lost the IQ Stream. It shows No Panadapter. What should I look for?
lost it where? On SmartSDR or something else? If you can provide more details and may be a screen shot it will help. Guessing you have restarted the radio and software and or PC?
For me this typically means you have to go to the left side of your pan where it says:
+RX
+TNF
Click on DAX and select an I/Q channel. Preferably the one you are trying to use.
There are certain things that are saved with global profiles and I've been bitten before by changing profiles and having something turn on or off that I didn't expect.
Hope this helps.0 -
Mark, That was it. Thanks. Still finding my way around SSDR!0
No worries Paul. This forum is full of helpful folks.
One thing about the flex radios that is confusing to me at least is the profiles and how for me sometimes when I just change bands it seems to select a different profile periodically and when that happens some settings can change as you just found out.
Now I'm using profiles to drive my band changes and it seems to help. You just have to get everything set the way you want it and save. Then recall it to switch bands.
Mark0
