KeepAlive() change request in the api
rfoust
rfoust Member ✭✭
edited February 2018 in SmartSDR API
In radio.cs, the KeepAlive() function has an if block to check if:
if (!API.ProgramName.Contains("Maestro"))
Any chance that can be changed to check for the existence of ProgramName to prevent a null reference exception?  Something like this:
if ((API.ProgramName != null && API.ProgramName != "") && !API.ProgramName.Contains("Maestro"))
Thanks!
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    I am guessing they do not check for this because you should set this value before calling Init.
    Here is what I do for FRStack
    API.ProgramName = "FRStack";
    API.Init();
  • rfoust
    rfoust Member ✭✭
    edited December 2017
    Yeah I've modified my code to do that now, just took a sec to figure out why it was blowing up. Either way, not a huge deal.
    Now I gotta figure out why keepalive isn't actually keeping it alive. Haven't played with the API in a few years...It has changed quite a bit. :-)
  • Eric-KE5DTO
    Note that KeepAlive doesn't run in Debug mode.  Only in Release.
  • Eric-KE5DTO
    Indeed, a ProgramName should be set before calling API.Init.  However, it could be checked and something more sensible shown to help the developer figure this out.  I've entered issue #5528 to address this.  Thanks for the report.
