Tune button works for 3 seconds then off
Mike NN9DD
Anyone ever seen a behavior like this on a 6500? There doesn’t appear to SWR or RF. When using tune button to tune up the radio will stop transmitting and go back to receive. Never behaved this way till yesterday. You press tune 3 seconds later it drops back to receive When using hand or foot switch will transit as long as trigger is pulled and behaves normally. Would appreciate any thoughts or experience others have had. Other wise I will reinstall software and reload firmware on radio Mike NN9DD
Mike, suggestion. Make sure you have ANT1 selected and connect this output to a dummy load, then see if you get the same results.
By any chance in SSDR setup under the TX tab do you have a value set in the TX timeout ? Sorry, doing this from memory so i may have the place wrong. Its in the same tab where you set delays for TX or PTT1,2,3.
I will check that when I get home tonight. I didn’t see anything. On those tabs out of normal but will double check Thanks and I will follow once solution is found Mike NN9DD0
I reinstalled the Radio and PC software and it seemed to solve the problem
NN9DD
- 407 Community Topics
- 705 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
