Does the Flex-6400 support the Ameritron RCS-12C Automatic Antenna Switch Controller?
K1SZO
I'm looking at setting up my Flex 6400 remotely and I have a couple of mono-band antennas. I was looking at the Ameritron RCS-12C antenna switch controller that can be programmed to automatically switch antennas based on the band you choose.
It says it works with several ICOM, Kenwood, Yaesu, radios and many others. That obviously doesn't list the Flex 6400. Does the Flex 6400 support band data output to allow the RCS-12C to automatically switch antennas on band change?
With the USB cable plugged into the rear of the 6400, the 6400 will feed BCD to the RCS12. So the answer is YES!...
Lou N2TU1
- 683 The Flea Market
