QSX on spot causes 6700 toRX on TX freq
Bruce Croskey
Using HRD DX Cluster spot with 6700 and when a spot contains a QSX, my 6700 goes to the QSX freq and not the DX freq... I have two slices open but all that does is cause the B slice to move 1KC up from the QSX freq..My IC781 has no problem with it and loads both freqs. and puts the TX on the QSX freq... What am I missing??
I suspect that the slice is being tuned to the frequency that HRD has instructed it via a CAT command. I also suspect that HRD is not putting the radio into split mode, so the radio is in simplex mode. Simply opening a 2nd slice does not put the radio into split mode; the ZZSW command has to be issued by HRD to put the radio into split mode and to take it out when it is done.0
- 690 The Flea Market
- 461 SmartSDR for Mac
- 112 Aurora
- 976 Genius Products
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
