rf power out
David Edgar
David Edgar Member ✭✭
I just got the radio back from service due to a blown U5. On AM/FM/USB/LSB I have good power out as shown by the SmartSDR program and the amp meter on my power supply. Using the FM mode when I key the radio I show 100 watts RF out and the PS shows about 20 amps.
However, when I try digital modes the program shows no power out and the amp meter on the power supply only shows about 5 watts of power used.
The RF power slider is set to max and my SWR is about 1.25 : 1 through the radios tuner to my 80M loop.
Before I sent the radio in for the blown U5, the digital modes had good power out as shown by both the program and the PS.
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited May 2020
    In digital modes, do you show audio levels in 3 places?  The digital program, DAX and the Radio Level?
    Make sure you have DAX selected on SSDR.
    If all that doesn't work, stop and re-start DAX.
  • k3Tim
    k3Tim Member ✭✭✭
    edited November 2017
    and verify the TX audio passband is set to pass the "tones".
  • David Edgar
    Where do I find that?
  • David Edgar
    Mike, I have a level shown in the DAX control panel TX stream that is almost full scale. I show very little change in the radio level. Nothing like it was before sending the radio in.
    Shut down DAX, SSDR and WSJT-X. Restarted them all. Still the same. I show almost full scale in the DAX control panel, not very much in the radio level. I am using FT8 mode and the isn't anything that shows audio level for that in the program.
    Shutting down and restarting only DAX changes nothing.
  • Bill W2PKY
    Bill W2PKY Member ✭✭
    Double check the Low and High cut settings s/b 0-4000
  • Mike va3mw
    edited February 2018
    Do you have DAX turned on as an audio source on SmartSDR.
    Have a look at page 127 and see if you missed anything.
    http://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf/
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited September 2018
    I've had the same thing happen to me twice in the past 2 weeks. Each time the problem is fixed by shutting down DAX and restarting it.  Just closing SSDR and restarting does not help. I had to close the DAX panel and restart it. This happened while I was using WSJT-X for FT8
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    In my estimation DAX is the weak link in the SSDR ecosystem. I do a lot of digital work and I must have to restart DAX at least 3 times a day.
  • Mike va3mw
    Hi Bob
    Yes, this is a known problem.  I do have to do that every once in a while.  We have logged it as a bug.
  • Jlawson40
    Jlawson40 Member ✭✭
    edited March 2020
    Since the later releases of V1 and now V2 ,I have removed both DAX and CAT from the computer start- up menu. Now I use this procedure: Boot up the computer and let it stabilize. Then start DAX followed by CAT and make sure they are running. Then start SSDR. Since using this procedure I have had no DAX , CAT failures or disconnects. This works for me on both laptop computers. DAX and CAT must be removed from start-up for each new release of SSDR. Might be something to try. John, W8AGS
  • David Edgar
    Start everything up this morning and now it works as it should. Nice full power signal.
    Don't you just LOVE computerized interfaces.
  • WK2Y
    WK2Y Member ✭✭
    Yea, there are days I long for my HQ 110 and Johnson Viking II. :-)
