Transmit audio phase inverted
W3AM
W3AM Member
The transmit audio on the 6500 and 6700 is phase inverted in AM mode when using the rear panel balanced XLR input.  Positive modulation peaks correspond to the - pin 3 on the XLR instead of the + pin 2 as they should.
Can this inversion be addressed in a future software update?  Should be an easy fix.  Using v2.0.17 now.
Tnx.
Gary W3AM
    This is a previously reported issue (defect #1920).  I'll add your comments to the defect description detail.
  • W3AM
    W3AM Member
    edited November 2017
    Thanks Tim, sorry to duplicate.
    No apologies necessary.
  • David Decoons, wo2x
    I reversed the wires in the XLR cable until a fix is in place Dave wo2x
  • W3AM
    W3AM Member
    Yes, me too.
