Big little shack computer
Martin AA6E
Member ✭✭✭
Running SSDR on a mini Intel NUC kit. Integrates nicely on the desk. Blog post.
Pictures! - or it didn't happen.
I've been running on a NUK5I7 for about 1.5 years with 2 monitors (1 native and the other USB Video Card) and I would not go back to a big desktop, my power bill went way down and the NUK5I7 runs on my stations 13.8Volt supply / Solar Batteries system just great.
Pictures? don't know what that would do over looking up the Intel NUK on line.
73's
Bret
WX7Y
With a 12V supply, I've just got to have one. I can pitch (re-purpose) my UPS!
It's not about pictures of the NUC, that's easy. It's about the shack running the NUC.0 -
Had me interested but I looked it up and the reviews says it does not work with Windoz 7. Would have been nice because it would run off my Solar bank of batteries just like my rig. Oh well. Thanks for the heads up.0
From the blog post:
What OS does it run??? This could put me closer to a battery backup station. 73, Jim0
We use NUCs for hamfest demo. They work very well.2
Been using one for about six months and to tell you the truth if the need ever rises I would buy another. Intel has a winner.0
Delbert,
The reviewers may have been correct in "their experience", Windows 7 works with most all NUCs. USB 3.0 had to have a special add-on. Here is a discussion of Windows 7 install and extra driver/installer for USB 3 use:
https://www.washingtonpost.com/opinions/the-carnage-will-continue/2017/10/02/59e51d62-a7ab-11e7-850e...
The NUC5I7 series does run on WIN7, I think that the NUC7I7 needs to run WIN10 for the USB C/Firbolt to work
IT DOES RUN on my 12V Solar system perfectly
Bret
WX7Y0 -
Are any of you using monitors that run off of 12v? I haven't seen many medium to large displays (27" or >) that run off of 12v DC.
Norm - W7CK
Norm,
I have two Samsung 24" 1080p TV/Monitors that have 12V external power supplies. They are pretty RF Quiet, unlike the Panasonic they replaced several years ago.
I have not tried to run them from my main 12V Shack Power supply (an Alinco DM330 that is also RF Quiet above 500 Hz) but I am sure I could if I wanted to. Eventually plan to put some Powerpole connectors and a fuse in their power line.
When I can afford to upgrade my two monitors to a single 4X UHD large screen (40-48 inches) then one of these will be moved to our Roadtrek mini RV and operated via the 12V supply lines.0 -
I have a pair of Samsung 4k U28E590D 28” monitors that are running off my station 13.8V supply. They came with laptop style AC to DC power supplies that indicated they were 14.0V output. I bought two extra ones really cheap off of eBay (kept the originals just in case I wanted to sell the monitors) and cut the cables on the monitor side off, added Anderson power pole connectors, and viola! Two less power supplies in the shack. Works great, no issues. Justin KL2D0
same here I have ZERO wall warts in my station,
Radios
NUC computer
Monitors
Powered USB3 Hub
ASUS Router
Netgear Ethernet switch
Speakers
Ethernet Power Switchs
Antenna switch
Plus all other accessories I have found and searched specifically for 12 to 14 Volt Opertion
ALL runs on my solar power Batteries
73's
Bret
WX7Y
I just bought a NUC5i7RYH (Core i7-5557U Gen5 , 8GB RAM, 256GB M.2 SSD). Should be absolutely perfect for the job.
Thanks for the tip!1 -
Thank you!0
@Gary - You gave us the wrong link!0
Using a NUC5i7 here with W10 with my new Flex. Absolutely perfect here as well. Gary WB9AYD0
Windows 7 will NOT work on any Intel 7th generation CPU. eg i5-7xxx 5th and 6th gen are fine.1
How many monitors will the NUC support and what resolution? I have a couple 29" wide screen monitors that are set at 2560 x 1080. Will the NUC handle them? Rich
I run with two wide screen monitors that are 25:9 which are like having 4 monitors. 34" diagonal. Works great! Gary WB9AYD0
NUC (seventh generation) claims to support 3 monitors through 2 I/O ports, HDMI (1 display) and USB-C (2 display streams, Thunderbolt 3). I use a simple USB-C to HDMI adapter cable to drive my second HDMI monitor. Check Intel specs here. Apparently good for up to 4096 x 2160 pixels each. Works for me!0
Thanks Martin and Gary.
Thanks Gary,
I'd like to upgrade to a pair of 34" monitors in the future. There was a big performance boost when I went to the 29" monitors.
I'd rather have pixels than inches and position the screen closer to the op. My two 22" monitors already take up too much space on my desk. (See my photo above.) Different strokes.0
Costco has these that I use. Great for multiple stuff going on that I can't fit on a conventional monitor. With my eyes bigger screen is better. As you say, different strokes.
LG 34UM61-P 34" UltraWide Full HD IPS Monitor
I've been using an i5 NUC running Windows 10 on my 6500 - two monitors. Works flawlessly - best change I ever made. Boot up time with the SSD is ~ 20 seconds.
Bret, were you the person I helped get VPN setup a few months ago? That is honestly the first I've heard of NUCs.0
Gary, I have an LG 29UM67-P. The power jack input says 19V DC. Does your 34UM61-P say the same? Do you run yours with 13.8V? What are the odds my 29" will also work with 13.8V?0
Yes, Martin, I ****-fingered the copy/paste of the URL. The correct URL is below, and as the post from G7BCX noted, there are limitations (although some *seem* to have over come those.
https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-nuc-kits/000017241.html
A Google search for this "Intel NUC Windows 7" will result in MANY entries about Win7 and NUCs.
- 692 The Flea Market
