CAT frequency not distributed permanently / Function of Flex USB to Serial adapter
DH1RK
DH1RK Member ✭✭
edited September 2017 in SmartSDR for Windows
Using V2.0.19 and have no permanently stream of frequency information.
New frequency information only distributed with frequency change.
Using DDUtil with RCP and B Cast setting.
Other devices which needs permanent data stream (e.g. microham StationMaster) stops functionality (e.g. 2nd antenna selection), because frequency information is unknown.
Is there a possibility to enable a permanent stream / repeated frequency information with a specific repeation rate (e.g. 2s)? Or other solution?
How does the new USB to Serial adapter for the FLEX-6000 series deliver the frequency information?
Thank you for reply in advance.
Ruediger, DH1RK
