version 1.11 Radio chooser Tab does not close
Rick WN2C
After upgrading to version 1.11 the radio chooser tab will not close. Click on it and it is a black box. I have SSDR 1.11 running but the chooser box will not close only minimize. Is this normal?
I don't remember this happening on earlier version. Should I not worry about or re-install?
Are you certain that you are not looking at the CAT application? It has a chooser option now.0
No Tim it is the radio chooser tab showing on the bottom of my display right along w/ SSDR-Win, SSDR Cat, HRD Rig control, HRD Logbook and the Chrome tab. I shut every thing down and restarted the computer and SSDR, SSDR Cat and it still comes up that way. Oh one other thing, SSDR Cat does not auto start when SSDR is clicked on to start the program like in the earlier versions.0
Anyone else see this? I have been running vers 1.11 SSDR for over 24 hours so it does not seem to be a problem but is this normal.?0
Well today I had a first time (ever I think) SSDR Cat disconnect. Had HRD running and lost connection w/ HRD. Not sure if it was HRD or SSDR that disconnected.0
From your description, this sounds like a Windows or something localized to your PC issue. We are not getting reports of this which would indicate a systemic behavior.0
Tim, if I close the radio chooser tab using task manager then both radio chooser and SSDR will close. It does not seem to affect the operation, but shouldn't it close once I click on the connect button?
As an aside, I will start using a windows 10 laptop and see what happens after I get 1.11 downloaded on it.0 -
I'd need to see a video of this behavior because I am not clear enough from your description what is actually happening.0
Attempting to open program. No radios displayed in chooser!
Attempting to open radio chooser. Nothing in the display.
- 684 The Flea Market
