60 meters lost with 2.0.17 upgrade.
Phill Beistel
Phill Beistel Member
edited April 2020 in SmartSDR for Windows
when trying to tune my antenna to channel 1 of 60 meters, The ATU refuses to do so. Even the Tune button does nothing. This used to work on 1.10.16 software. 1.11.12 also fails. What happened?
  • Phill Beistel
    edited September 2017
    I also upgraded to 2.0.19 with the same result. Seems to have happened between 1.10.16 and the 2.0.17 release.
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Check QRG and TX bandwidth
  • David
    David Member ✭✭
    If 5.330.5 is used the tune button is available but as Phill stated it does nothing. If 5.330.55-5.330.7 It will tune and TX.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    Wonder if there is a Beta check list?
    In SSB and DIGx modes, TUNE is done on the carrier frequency to prevent QRM in the receive passband.  On 60m, this is a special case because you are at the edge of a channel and emission is not allowed at the carrier frequency because some of the RF energy is outside of the channel designation.  You need to tune to a frequency inside the channel bandwidth to use the TUNE feature as indicated by David above.
  • Phill Beistel
    Many thanks. I tried that solution and it works. I guess I'll just have to remember that for next time!
    73's
    Phill (wb3dhf)
