Is there a Memories channel configuration page for the 6500?
DJH27521
Is there a Memories channel configuration page for the 6500? I found one for the 1500 (http://kc.flexradio.com/KnowledgebaseArticle50500.aspx). I am configuring a 2M transverter and cannot get the setup for the local repeaters. No problems with simplex.
Hi David
Check the manual http://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf/
Chapter 22 on page 93.
Does that help at all?
Mike0 -
I've looked at that part of the manual and I got some of it figured out. I am not sure of the "step: and the "repeater offset" settings. Will the Frequency on the display change to the offset frequency when the radio is keyed?
That's what it did for me. TX displayed the offset and RX displays the repeater output frequency.0
What are the values used in "step: and the "repeater offset" settings?
Now it's telling me that the transmit slice has not been selected.
If you were already tuned to the frequency all those settings will be imported when you save it0
I saved the frequency but it doesn't work. I must be overlooking something.
6 meters Fm work correctly.
2 meters transverter bought on ebay does not work. http://www.ebay.com/itm/144-to-28-MHz-ASSEMBLED-TRANSVERTER-2meters-2m-144mhz-146mhz-VHF-UHF-Ham-Rad... d0
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
