Strange Smartlink and router behavior
My network is connected to the internet via an Atlantic Broadband cable modem. The cable modem is a Cisco DPC3827 modem/router. This cable modem enables Upnp by default and I logged into the modem and verified that was enable.
Myself and another Flex owner tested access to my Flex via Smartlink. Below is a summary of results.
1. Remote LAN to my Flex via broadband cable modems - success (2 different locations)
2. Remote connection via Verizon cellphone hotspot - failure
3. Remote connection via Karma Go hotspot - failure
At this point I was blaming port blocking on the hotspots. As a last thought I tried port forwarding of the Smartlink TCP and UDP ports on my cable modem (Upnp is still enable).
Success on ALL connections!!!! I do not understand this behavior but everything is working!
Out of curiosity, using your hotspot and Verizon (LTE?) before port forwarding, was the radio discoverable even though you could not establish a connection?
Jim, K6QE
Yes, once the email id and password were entered the radio was available. However, the Smartlink test failed and the remote could not connect.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
