hot to control waterfall display on 6300
Robert Kearbey
slice A waterfall "signal" is 5 to ten times higher than slice b. radio 6300
thanks bob
You can drag the db scale on the right hand side of the display for each panadapter to set the limits.
Also at the top of the scale is an up and down arrow to change the actual scale.
Kev0 -
I know some of you might not believe it, but there is a manual.
(apologies if you have vision issues)
http://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf/
Chapter 11 does a great job of explaining it.
I went to Staples and printed a copy for not too much expensive and had is spiral bound. Very handy for making notes in.
73, Mike va3mw
Amazing.0
RTFM = Read The Flex Manuals. ;-)1
