2.0 registration
KC7ES
KC7ES Member ✭✭
edited March 2019 in SmartSDR for Windows
Took a few tries of the PTT foot switch before it took. Waited a few seconds into the timer window and held the switch a couple of seconds. Got it on the third try. If you run into this issue, don't give up. Might have been network issues, but otherwise a smooth upgrade to my 6300.
  • Joe - KC2TN
    Joe - KC2TN Member ✭✭
    edited July 2017
    I had the same issue with my foot switch. It works fine for keying the Amp/radio but wouldn't work for the registration process. However, when I switched to using my KEY instead, it worked the first time. Mystery!
  • Rudy HB9MHB
    Rudy HB9MHB Member ✭✭
    edited July 2017
    I had the same with my PTT on the microphone, I need four times then was ok.
  • Rick Hadley - W0FG
    Rick Hadley - W0FG Member ✭✭
    edited January 2018
    It just took a quick tap on the Begali paddles for mine to register.
  • KC7ES
    KC7ES Member ✭✭
    edited July 2017
    I may have found the issue..I inadvertently left my laptop upstairs on, and connected to the LAN. Both DAX and Smart SDR Cat were running (v 1.10.16). That might have caused a conflict. Note to self...
