Versions v 1.10.16 radio and v 2.0.17 radio on same network and one PC
K3SF
Member ✭✭✭
The condrum i present is how to setup a PC on a Lan that has one Flex running ssdr V1.x and another flex radio running ssdr V2.x..
It is my understanding that DAX/CAT of V1.x and V2.x are different and that they can not be installed on the PC at the same time.
A corollary to this above Lan setup would be a WAN setup, where my home setup is flex radio running V1.x but a friends offer me to connect via smartlink to his flex radio running V2.x.
Question, can V2.x SSDR Dax/Cat on the PC work with a Flex radio running ssdr V1.x? This implies that the PC is running SSDR V1.x
with V2.x Dax/CAT installed.
Thanks for any insight for proper configuration for these setups.
I do this on my LAN. Use a filter.txt file on each computer. Search the manual for details. Mack W4AX Alpha Team0
hi mack
thank you for your response
i could not find in the SSDR Software User Guide for V2.x dated 25july2017 any reference to the filter.txt setup.
but
i understand about the use of the filter.txt file to help the PC SSDR in choosing a single flex radio or even a reduced list from the helpdesk pages on filter.txt
In my case , I assumed it would not be necessary as each flex radio would be running different version of SSDR. One radio running SSDR V1.x and the other running SSDR V2.x.
Sorry i guess i didnt make myself clear.
My real question is can both DAX /CAT V1.x and DAX/CAT V2.x be installed simultaneously on the same PC without causing any issues to running both SSDR V1.x and SSDR V2.x on the PC.
...Note.... that i do not intend to be running SSDR V1.x and V2.x on the PC at the same time. Other than DAX/CAT conflicts i dont see why i should not be able to run a ssdr v1.x and ssdr v2.x simultaneously
Sorry, I misunderstood the original question. One same same PC you can have 1.10.x loaded and then load 2.0.17 on the same computer. I have at least 20 versions (I need to go clean some out) of various Alpha SSDRs and they work fine. I have hardware and software that I test with 1.10.x and I simply select the version I want to run from the Start menu for my 6500 running 1.10.x and my 6700 running 2.0.17 each work without upgrades.
I'm 99% sure the CAT and DAX from 2.0.x are backwards compatible with 1.10.x. Hopefully this will get you going.
Mack
W4AX
Alpha Team0 -
hi Mack
that is what i was hoping would be the case.
right now i am without a flex radio to test with...
i did a trade in of my 6300 for 6600M so i could not actually test it myself.
This also helps answer another question of a friend who we hope will be able to remote into my 6600M when i get it setup here. He currently runs a 6300 with V1.10.x. So having both ssdr V1.10 and V2.0.x on his PC was a concern he had too.
your real life experience with the s/w is the best kind of answer.
thanks
DAX and CAT 2.0 are NOT backward compatible with SmarSDR v10
I wonder if it would be possible to run ONE of the radios in a Virtual Machine on the same machine?0
Tim
Thanks for the Official response. That is what i thought but really needed to be verified explicitly as i was not able to find it in any documentation.
So as a followup question.
How does FRS recommend installing both ssdr v1.x and v2.x on a single PC which has a network of flex radios running with one running ssdr V1.x and the other flex radio running ssdr V2.x?
Gary
yes that is possible as the VM and the real PC it (aka the host) is running on are effectively two independent machines...
i have run a win7 VM running DAX/CAT and cwskimmer connected to my flex 6300 and at the same time the host was a MAC mini running macos and dogparkSDR connect to the flex 6300 for panafall display and control.
