fldigi set up (cat )
Keith Morrison
Can anyone tell me how to connect my Flex 6300 to the Cat control on Fldigi as I am stumped! I have the PTT set up as when I open the program the TX goes on and off (shaking hands with PC?) I have downloaded the xml file for power sdr slice A from the rig cat download and installed it in the correct folder but still nothing happens no control it has my head battered Oh by the way I have created a cat virtual com port too still nothing. Any help would be good using windows 10
thanks Keith M1VHT
thanks Keith M1VHT
Thanks for the reply Tim, followed both the video and set up guide to the letter and still no luck it's driving me mad thanks Keith
what version of Fldigi?
Is the Power SDR xml for slice A the same as the SmartSDR xml? Wrong file?0
They are very different.0
He states he was using Power SDR xml file with 6300. Misstated?0
Hi, fldigi is version 4.0.7 the latest I believe? operating system is windows 10. rig description file is SmartSDR_SliceA.xml. baud rate is 56700. The cat control on HRD works fine so not sure what is wrong
above is a screen shot of my cat control settings thanks Keith
I have heard that there was a program change with Fldigi 4.0.7 that breaks RigCat if the com port stopbit is set to 1. This is the way SmartSDR (and PowerSDR for that matter) have been configured since the beginning of time.
You can use a text editor to open the RigCat XML for SmartSDR and modify the default value of 1 to 0 in the tag pair as shown below:
<STOPBITS>0</STOPBITS>
I just took a look at the Fldigi Yahoo page and many people are complaining that 4.07 broke RigCat and are reverting to v4.0.60
I have just confirmed that multiple versions of Fldigi up to 4.0.6 are working with the available RigCat XML files for both PowerSDR and SmartSDR and version 4.0.7 does not.0
Thanks Tim! Changing the STOPBIT value to zero fixed my Fldigi 4.07. Yippee!
I have it on good authority that this bug is being looked into and I am sure it will be corrected in short order.0
Haha, so cool! I have the exact same problem right now. And found this info... posted 3hrs ago! TU! /730
Don't get used to the workaround. I just finished some validation testing for Fldigi v4.0.8 and the RigCat bug looks to be fixed. Once the new version comes out, you will need to change the stopbit back to 1 because "0" is not a valid option for that parameter.1
See my response below to AA5JD John. The workaround is temporary. Fldigi 4.0.8 resolves the issue.0
Success at last, used v3.23.15 everything fell into place without any problems. Thanks to all who replied and helped me. Will be interesting to know when the bugs are fixed in the latest version of Fldigi
regards Keith M1VHT
I ended up using FLrig. Works well... I generally find fldigi to be a pain in the neck (pain is actually much lower...) when it comes to rig control but once you get it working just virtually apply superglue to the controls.
Tim-Running SSDR CAT v 2.0 and Fldigi 4.0.8, but Fldigi doesn't always "see" CAT port 7. I have to shut down both CAT and Fldigi, relaunch both, then it sync's up, but a pain to have to do this. Are others having issues with v2 and Fldigi?
Thanks!0 -
I always assumed it was because I am dumb but I have also viewed Fldigi CAT as a "pain". I eventually get the right config to make it work but there is something about it that is counter-intuitive especially if trying a separate CAT port with ye olde PowerSDR. Using VSP's with DDUTIL makes it less of a pain but them you had to deal with multiple issues from disappearing virtual serial ports every now and again.
Andy K3UK0 -
I am running 4.0.9.8 and I am not having any issues with RigCAT.
Are you using the latest version of the SmartSDR_SliceA.xml file?0 -
I've found an issue, not only with fldigi but with AC Log also communicating with the port on SmartSDR CAT. SSDR CAT reports the the application are attached to the correct com ports, but they are not polling correctly. Solution is to shut down SSDR CAT, then start it again, then all programs communicate correctly. Is there a means to un-install just the SSDR CAT and re-install?0
Tim, not working for me in January, 2019. Both the narrative and the video are now outdated to my eye. For instance, the video shows us DAX ver 1.2.17.0 while my current ver is 2.2.8.
Sooo, I have established DAX audio. My problem is CAT rig control for the latest FLDIGI ver 4.0.18. I've downloaded and installed the file SmartSDR_SliceA.xml from W1HKJ, confirmed a free port, COM7. Initialized. No rig control.
SmartSDR ver 2.2.8 operating with Windows 10 latest update. Guesses?0 -
David
You've resurrected an old zombie thread about a slightly different and rather temporary SmartCat/Fldigi problem, If Tim w4tme. fails to respond to your post here, I can help you out, in the #FlexRadio IRC chat channel.
For real-time discussions
User-created documentation.
Volunteer!!73, Jay - NO5J
Jay, you are too kind. I’ll take your advice with pleasure. Shall we set a time/date to IRC chat? I’m PST in LA. Early mornings, or late afternoon through early early evenings good for me. Many thanks — I’m close, but not there yet. David A. KK6DA, Los Angeles.0
David
I'm mostly available from around noon CST to Midnight CST, If you don't get a response in the IRC channel I may not watching it closely enough, I get audible notifications on any channel activity. Try to hang around long enough for me to respond. I'll make a metal note to keep an eye out for you when you join.For real-time discussions
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 473 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
