Suggestion for next iteration of Maestro
Andrew Thall
Andrew Thall Member ✭✭
edited May 2020 in New Ideas
At the Hamvention, I was very impressed with the large-screen display coming from the 6600M.  Could you add a HDMI port to the back of the next generation of Maestro boxes?
Andy, k2oo
2 votes
In Review · Last Updated
  • Eric-KE5DTO
    edited July 2017
    Thanks for the feedback Andy.  We will take this into consideration.
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    Display Port would be preferred so one can daisy chain several displays in a series connection. Toss in a Mira cast for good measure.
  • Ria
    Ria Member ✭✭✭
    edited July 2017
    Displayport or a modern connector like USB-C would be a lot more flex-ible. I suspect though that they will be limited by whatever OEM tablet module they use. I think that 1080p HDMI is fine for most uses.
