Getting an annoying screen Using Flex 5000a
Rick
Rick Member ✭✭
I'm getting a screen on the PC even tho I'm using the proper shut down sequence, ( PowerSDR and then the Flex) Thanks for your help in advance...Rick, kd4dra
    edited June 2017
    You need to view the problem details since this is a generic crash message.
  • Rick
    Rick Member ✭✭
    edited June 2017
    Ok I'll try again , didn't understand them before. Thanks
    edited June 2017
    Do a screen shot and display them so I can attempt to determine what is faulting.
  • Rick
    Rick Member ✭✭
    edited June 2017
    OK thanks. ..I'll do it when I get home.
  • Rick
    Rick Member ✭✭
    edited June 2017
    I had to take 3 screenshots to get it all, hope you can read it.
    Thanks Rick
    edited June 2017
    Reset the database. Looks like there is an invalid value in it somewhere
  • Rick
    Rick Member ✭✭
    edited June 2017
    In the powersdr program
    edited June 2017
    Yes, the factory reset option is in Setup.
